LCD Sreen stuck
By Armyman · Jun 15, 2007in Problems/Troubleshooting💬 8 posts👁️ 1,278 views
Posted Jun 15, 2007 · 12:18 UTC#1
I' sent my AVIC-D1 to Pioneer two times because the screen didn't slide down when I try to access the DC/DVD slots and I'm about to send it back for a third time In less than a month for the same thing.
Does anyone have any idea what the problem can be, the guys over at Pioneer are batting a Thousand. :evil::evil:
Posted Jun 15, 2007 · 12:36 UTC#2
My d1 used to do that. It was caused by the opening in my dash was rubbing against the unit. Hope this helps
Posted Jun 15, 2007 · 12:37 UTC#3
KEEP PUSHING THE EJECT BUTTON
If you push it and release, it will only go down half way
Posted Jun 15, 2007 · 13:17 UTC#4
I think he means it won't move at all.
Posted Jun 15, 2007 · 13:48 UTC#5
When I push the open button nothing happens. It's like the thing is dead
Posted Jun 16, 2007 · 00:50 UTC#6
Remove the unit from the dash, and unscrew any brackets on the sides of it. With it powered up in your hand try hitting the eject button. If it moves, then the problem is the install.
Posted Jun 16, 2007 · 03:31 UTC#7
Everything was fine until about two months ago. I've had the thing for almost two years.
It's in a 05 F150 so there is nothing it the way of the srcreen.
Posted Jun 16, 2007 · 05:23 UTC#8
Like I said try removing the screen from the dash kit and hitting the eject button. The screws going into the sides of the unit may be causing the mechanism to bind up especially if they're screwed in too tight.
