no speedo after vss hookup
By cs209102 · Jun 16, 2007in Problems/Troubleshooting💬 17 posts👁️ 2,266 views
Posted Jun 16, 2007 · 01:37 UTC#1
Starters: great site with tons of help, used this site to guide me through my install of a D3 in my '07 chevy colorado.
The Problem: i installed my D3 a few days ago minus the vss wire, of course the speed pulse was reading zero but the distance, left turn and right turn were "learning". now that i have my vss hooked up, it ramps up and down with acceleration/deceleration, it keeps counting the pulses it recieves in the 3D calibration window but it went from "simple hybrid" to "sensors initializing" and when i go to connection status after i hit 30 mph or so it gives the "irregular speed pulse" warning and shows im always going 0 mph... it only gives the speed pulse warning when i go into the connection status window
So, am I good and need to drive for a while or is there something bad the matter, i tried both yellow/black wires coming from my blue PCM plug, one did as i decribed above and the other just gives a single blip everytime i shift gears (auto tranny)
Thanks in advance for any input!
Posted Jun 16, 2007 · 05:25 UTC#2
Have you tried resetting the learning status?
Posted Jun 16, 2007 · 05:26 UTC#3
ive hit the reset button by the eject button, is there another reset?
im scouring for it through my owners manual as I type this
Posted Jun 16, 2007 · 05:32 UTC#4
in the learning status screen, clear each of the lines.
Posted Jun 16, 2007 · 05:34 UTC#5
thanks, ill go try it right now!
Posted Jun 16, 2007 · 05:48 UTC#6
well i reset all 3 things but it still gives the irregular pulse warning, got up to about 40mph and the pulse was about 300, and now for some reason everytime i turn it on it gives me that damn store demo "press OK to start navigation" screen. it still show me at 0 mph and doesnt count the distance anymore
Posted Jun 16, 2007 · 05:53 UTC#7
Speed Sense yellow/black PCM, blue plug, pin 25
That's the wire you tagged for vss? The store demo screen will go away after a couple cycles. If it's giving you that much of a problem, I'd say disconnect it and leave it disconnected.
Posted Jun 16, 2007 · 05:59 UTC#8
yeah thats the wire, there are 2 yellow/black wires coming out of the blue harness and the other just gave a single pulse each time the trans was put into gear. what i dont understand is why it would read 0 mph, as i drive my position on the map changes and im able to navigate with "OK" accuracy but i want all that i can get out of it. it is bypassed so it shows the parking brake as set if that matters?
Posted Jun 16, 2007 · 06:07 UTC#9
Nope bypass has nothing to do the with issue you're having. The only thing I can come up with is the vss in the truck is a nonstandard signal that the avic is unable to properly interpret. If your truck has abs, you could go directly to a wheel speed sensor for vss.
Posted Jun 16, 2007 · 06:13 UTC#10
i just read in a colorado specific forum that someone in an '06 found their vss wire to be a solid light green wire coming out of the blue harness, any chance the yellow/black is only for '04-'05?
Posted Jun 16, 2007 · 06:16 UTC#11
It's possible, the info I posted is shown for the 06 and 07 though. It wouldn't be the first time that database was wrong though.
Posted Jun 16, 2007 · 06:17 UTC#12
does your source show any info for a light green wire on that plug?
Posted Jun 16, 2007 · 06:21 UTC#13
nope nothing. The wire you tapped into was it in pin 25? if not, then try the wire in pin 25. In gm's especailly, the wire colors may change, but the pin locations rarely change.
Posted Jun 16, 2007 · 06:28 UTC#14
i have no way of knowing for sure without breaking the harness apart, there arent even any discernible numbers to know which pin is which. Thanks for the info, ill poke around tomorrow and look for a light green wire.
Posted Jun 16, 2007 · 06:33 UTC#15
Look at the plug with the locking tap facing up. Then just count left to right top to bottom til you get to 25.
Posted Jun 16, 2007 · 06:41 UTC#16
this is a pic from my colorado forum and the circled pin is the one they say is 25 but i dont count that to be the 25th hole counting any direction
Posted Jun 19, 2007 · 02:53 UTC#17
I'm having the same issues on my 07 Colorado as well... Pin 25 is a yellow and black wire, but my D3 reads the pulses but doesn't calibrate them, i have full bars on the Left and Right turn 3D status but nothing else....
So don't feel bad, your not the only one in that boat, or truck that is...
