hi,
my avic d1 face does not open after I press button open or angle. I do not hear the motor opening the face running.
please help.
thank you
hi,
please help.
thank you
Remove the unit from the dash. Take off any brackets screwed into the sides of it. If it still won't eject then you have a problem with the unit. If it does eject then it's an installation issue.
thanks. I just removed the units from the car and it opens.
What kind of car is it?
I had the same problem. I just hit the reset button and that fixed the problem
I have the exact same issue. Im not sure if its an intsllation issue cause i had the unit intsalled for almost 2 years now with no problems. All of a sudden the open and angle buttons dont respond. The first time it happend I had to turn off the car (kill the power) and turn it back on. It worked fine. This time however that fix no longer works. I cant open the face of the unit.
Any one have any other ideas?
mine does the same thing but it started when I did the ebrake mod. my screen will not open and my vehicle dynamics dont work anymore. both only work when truck has been sitting overnight and I just turn the key to the accessory position, I tried the reset button and it didnt work... any ideas??
i had a buddy of mine with the same problem exept his motor got stuck took out the unit the brackets tried to reset nothing grabbed a screwdriver taped the bottom of the radio with the screwdriver head where the motor sits and boom it opend right up give it a shot
If you installed it with a certain kit (can't remember brand). The face plate has a lip on the inside that will catch the rail that it slides on. I had to remove the face plate and dremel a small groove for it to slide in. Took about 5 mins. Hope that helps.
TJ
I've had this same problem with my D1 recently. It's been installed in my truck for almost two years without a problem. It's an intermittent problem though. Sometimes the reset button works, sometimes it doesn't. If the reset button doesn't work, I just leave it alone for a few days and for some reason it'll start working again...
Weird...
Anyone else have these issues or know of a resolution?
Guys it's a temperature thing. Mine doesn't open if it's above 75F outside. I think it's a cold solder joint somewhere.
