2005 mustang VSS/dimmer wiring
By official_style · Jun 18, 2007in Vehicle Specific Wiring💬 8 posts👁️ 2,269 views
Posted Jun 18, 2007 · 22:36 UTC#1
since my car has the shaker 1000, is the vss wire connected to the radio currently? i heard this car has oss, not vss, does it need some kind of adapter before connecting it? also, what about the dimmer wire? where do i connect it to?
im about to have an avic z1 installed.
Posted Jun 18, 2007 · 23:28 UTC#2
If you're having it installed, then why do you need to know where to find those wires? The installer will have that information.
Posted Jun 18, 2007 · 23:31 UTC#3
You are gonna need to get illumination(dimmer) from your switches on either side of your cig lighter above the radio.
Posted Jun 19, 2007 · 00:33 UTC#4
thinking about maybe doing it myself.
Posted Jun 19, 2007 · 01:36 UTC#5
Speed Sense dk. blue/yellow ac PCM, top plug, pin 3
The PCM (Powertrain Control Module) is in the front passenger side of the engine compartment.
you could use the negative parking light wire and run it through a relay
Parking Lights- black/lt. green - sw. or SJB, blu 52 pin plug, pin 31
The SJB (Smart Junction Box) is in the passenger kick panel.
Posted Jun 19, 2007 · 01:41 UTC#6
I just installed a D1 in my 2007 Mustang, and a D3 the week before in a 2005.
I found it's easier to use a wire tap on the illumination wire at the headlight switch.
The switch pulls straight out, and if I remember correctly, the 2nd wire from the bottom on the right side of the left plug is +12 when the lights are on.
I did not connect the VSS because I didn't want to run a wire through the firewall.
Posted Jun 19, 2007 · 03:31 UTC#7
good thing i asked, according to the rostra site, this is what it said:
VSS Wire: LOCATION 1- POSITION 68 0F 104 PIN CONNECTOR OF PCM
VSS Wire Color: WHITE/ORANGE
Posted Jul 04, 2007 · 01:37 UTC#8
well i had it put in by my installer. love the unit, it works great, however i have one problem. something is wrong with the dimming, it will only dim with the parking lights on (will not dim with headlights on) and sometimes it wont even dim with the parking lights on. im thinking i should tell him to change the dimming wire to one that is on the switches by the cig lighter, as stated by someone above.
