D1 Avic GPS not working
By avicd1Z · Jun 18, 2007in Problems/Troubleshooting💬 4 posts👁️ 796 views
Posted Jun 18, 2007 · 23:29 UTC#1
hi,
my D1 GPS is not working. I connected the GPS antenna and it says I'm in LA while i'm actually in the bay area. I checked the connection status, it says GPS is "NOK".
I already connected the GPS antenna and put in clear sight under the winshield. It's still not working
thank you very much for your help.
Posted Jun 18, 2007 · 23:30 UTC#2
Try putting the antenna on the outside of the vehicle temporarily.
Posted Jun 23, 2007 · 23:18 UTC#3
I put the antenna outside the car, still no signal.
The GPS wire was cut in half, so I had to rewire it.
could this be the problem? do I need a new GPS antenna?
thanks
Posted Jun 23, 2007 · 23:47 UTC#4
Yeah that'll do it. you'll need a new antenna. If you want to send me the broken one, I can try to repair it. How far from the antenna and the connector is the cable damaged.
