DVD BACKUPS????
By lswift84 · Jun 19, 2007in General💬 8 posts👁️ 1,302 views
Posted Jun 19, 2007 · 00:38 UTC#1
Has anyone made a copy of their original NAV cd and used the copy in the drive instead of the original?
I don't want mine to get all scratched up in the car just wanna keep a copy and leave the real one at home.
is it just burn a copy with Nero and let it work? I would test it but I don't have any blank dvd's on me. (oh yea do they need to be dual layer?)
Posted Jun 19, 2007 · 00:52 UTC#2
Yes copied backup Nav discs work fine :) They do need to be dual-layer, unless you start deleting POI files, but that is a mess upon itself. When you start deleting POI files, you actually lose the ability to search for some addresses stored within the POI files. I suggest just going with DL discs
Posted Jun 19, 2007 · 01:25 UTC#3
thank you for your help i will pick up some DL DVD's, is it as simple as doing a copy disk in nero?
Posted Jun 19, 2007 · 02:13 UTC#4
I use Alcohol120%, but many people here have used Nero with no problems whatsoever.
Posted Jun 19, 2007 · 14:31 UTC#5
If you use Alcohol, be sure you have the latest version. Some of the older ones didn't burn DL media too well.
I used UltraISO to make a .iso image and then Nero to burn that image.
Probably an extra step that most don't take, but it always works.
Posted Jun 19, 2007 · 20:09 UTC#6
i used nero and works perfect
Posted Jun 20, 2007 · 02:59 UTC#7
does it have to be a DVD-R DL or can it be a DVD+R DL?
Posted Jun 20, 2007 · 03:52 UTC#8
+R DL will work just fine.
