Amp Blown?
By stathound · Jun 19, 2007in Car Audio💬 4 posts👁️ 1,901 views
Posted Jun 19, 2007 · 17:09 UTC#1
Yea, I know this is an AVIC forum, but most of you guys are talented enough to cover all parts of the field. Last night I was doing a little too much partying and somehow this morning found my amp not coming on and my ground wire was disconnected. Would this cause it to blow? I reconnected the wire and it still won't go on, the fuses are fine btw. Thanks for the help guys!
Posted Jun 19, 2007 · 20:54 UTC#2
If all of the fuses are good, including the one under the hood, and the ground point is tight. Then yes you can fry and amp if the ground comes loose and hits the chassis of the amp.
Posted Jun 19, 2007 · 22:09 UTC#3
hey whats the model number of the amp because i've have a memphis amp internal fuse's...and sorry have u check the remote wire t turn on the amp?
Posted Jun 19, 2007 · 23:54 UTC#4
Well now its cutting in and out, I'm like 50% sure its the grounding. I bought some 4AWG to ground it properly shouldn't be a problem now. The model is KAC-9102D. :) Thanks for the help! :D
