fm radio problem
By wlman1959 · Jun 19, 2007in Problems/Troubleshooting💬 11 posts👁️ 1,375 views
Posted Jun 19, 2007 · 22:34 UTC#1
I am having trouble with FM stations it appears that i am losing singal strenght my antenna is in my back window i am wondering if this is the cause of my problem with stations being weak, I am also wondering if i need to hook up the blue antenna wire from unit, or am i getting interference from some where, I made sure that all my connection were nice and tight, on the display of unit i am only seeing two to three bars , I used the program to lock in the station but still having problems
please help
Posted Jun 19, 2007 · 22:42 UTC#2
yes the blue antenna wire sends 12v to ur antenna.... if you have car amps it is also used as a turn on switch
Posted Jun 20, 2007 · 00:09 UTC#3
whats the year, make, and model of your car?
Posted Jun 20, 2007 · 01:29 UTC#4
year 2002 XG350L Hyundia
Posted Jun 20, 2007 · 01:41 UTC#5
nope, no listing for an amplified antenna.
Posted Jun 20, 2007 · 01:51 UTC#6
so I do not need to hook up blue antenna wire to 12 supply?
Posted Jun 20, 2007 · 01:55 UTC#7
no, thats not how you hook that up anyway. the blue wire supplies 12v to the antenna amplifier in some cars or it turns on the motor of a power antenna. did you hook up the blue/white from the avic to the green/red in the radio harness?
Posted Jun 20, 2007 · 02:01 UTC#8
I am not sure I will check tomorrow and let you know, If I did not hook up would that cause my problem
Posted Jun 20, 2007 · 10:18 UTC#9
probably not, but its worth a shot, and make sure you plugged the antenna lead in all the way
Posted Jun 20, 2007 · 11:29 UTC#10
MisFit, it's 6AM. go back to bed. I have an excuse, I wake up for work at 2AM LOL
Posted Jun 20, 2007 · 23:35 UTC#11
yeah, i got too much shit to do. gotta cut corners somewhere, so i just dont sleep anymore. but i get a lot done :lol:
