I have posted several times about battery drain after my D3 install. I'm pretty sure I have found the culprit...the gmos-lan-04. I reinstalled the factory head unit and powered everything off....current reads .13 on my amp meter. Reinstalled the D3 with the gmos-lan-04...current reading .74. Took the 04 off line and the current returned to .13. Should the gmos-lan-04 have any current draw when the power is off...it is hooked up to constant power. Is this just a bad lan unit?
Thanks all...
vtail
