Installation help
By ReeferMAdness · Jun 19, 2007in Problems/Troubleshooting💬 3 posts👁️ 664 views
Posted Jun 19, 2007 · 23:44 UTC#1
OK so i got my d3 yesturday my wiring harness and mounting kit i was soo happy that dimished quickly once i had everything wired up and the deck wouldn't light up at all. Now there are some wires i didn't hook up but that shouldn't make a difference......the pink car speed signal input and the violet/white reversegear signal input. other wise everything is as it should be besides the bypass. I took the green long wire and the mute wire and grounded it to the black cable on the wiring harness(after moving it up one slot). Now theres also an auto-antenna relay thats not connected up i have an 06 mustang and there is no auto antenna. If you guys need more info pls ask but im flat out of ideas the thing wont turn on period.
Thanks in advance
Posted Jun 20, 2007 · 00:09 UTC#2
Check All of the fuses in the car. Betcha one's blown.
Posted Jun 20, 2007 · 02:10 UTC#3
wow do i feel like an idiot it was a blown fuse and after all the time i spent rewiring thinking i did something wrong. Thanks man!
