vss wire on 2003 volvo s60
By bill677 · Jun 20, 2007in Vehicle Specific Wiring💬 14 posts👁️ 2,707 views
Posted Jun 20, 2007 · 18:07 UTC#1
Hello to everyone on the forum. i have recently installed an avic d3 in my 2003 volvo s60. currently i have been running without the vehicle speed sense wire connected. just curious if anyone knows the location of the vss wire on my car. any help would be great.
thanks
Posted Jun 20, 2007 · 19:47 UTC#2
ECU MODULE TO THE RIGHT OF GLOVE BOX PIN 14 OF A 26 PIN PLUG, PURPLE WIRE. Sorry for the caps, I cut and pasted.
Posted Jun 20, 2007 · 20:02 UTC#3
Audiovox paste job?
Posted Jun 20, 2007 · 20:05 UTC#4
You've got it. Audiovox is hit or miss and Directech had nothing.
Posted Jun 20, 2007 · 20:10 UTC#5
Yeah, the only thing I don't like about audiovox is sometimes their descriptions leave a lot to be desired.
Posted Jun 20, 2007 · 20:14 UTC#6
I use their info as a guidline in the direction I should look. Then test, and double test every connection.
Posted Jun 20, 2007 · 20:50 UTC#7
Testing eh. Na don't ever do that, course that's why I now have bcms from a dozen different cars :lol:
I'm joking just incase anyone couldn't' figure that out.
Posted Jun 23, 2007 · 15:32 UTC#8
I need the same (VSS wire location/color) info for a 2004 Volvo XC90, please...
Posted Jun 23, 2007 · 16:36 UTC#9
Same location and color as the S60.
Posted Jun 24, 2007 · 16:00 UTC#10
Thank you so much, shotgun...
Do you happen to know the ILLUM wire location as well?
Posted Jun 24, 2007 · 16:20 UTC#11
Red/Black, positive polarity, behind radio
or
Gray or white, positive, fuse box
Posted Jun 24, 2007 · 22:00 UTC#12
WOW 20 min response. Can't thank you enough...
Which fuse box? There is one in the engine compartment, one in the driver side dash, and one in the back near the left tail light.
Posted Jun 25, 2007 · 03:33 UTC#13
Not sure. I would try the drivers side first.
Posted Jun 25, 2007 · 14:25 UTC#14
I was wrong on the VSS for the S60 and the XC90.
Sorry if this caused any problems.
Audiovox has nothing and Directechs says at the wheel speed sensor.
