Need some help with the Pink (car speed) Violet/white (reverse) wire location. Thanks
Posted Jun 20, 2007 · 21:18 UTC#1
Vss is gray/bblack in the radio harness(pink wire). Reverse is black/pink in the back of the fuse panel in the driver's kick area(purple/white wire).
Could you be a little more specific on the reverse wire. I have a couple of wires that look black /pink, and are 8 pin. If possible could you give me the fuse or relay # from the front of the fuse cover. (example: relay 14 or fuse 12) Thanks!
That's all I have and the picture I took was so blurry you couldn't tell. Best bet is test them.
