XM Updatin WHAT THE F*** !!!!
By Cruznlife1 · Jun 21, 2007in General💬 8 posts👁️ 1,215 views
Posted Jun 21, 2007 · 00:16 UTC#1
Okay, 4 days ago, I started getting a message "XM Updating" I've seen it before it usually goes away after a couple of minutes.
It's been on for 4 days now. I can't even use my nav, because I have a big box covering the screen, XM Updating. I hit okay it comes back on 2 seconds later. I drive an hour to work each way and get "Very Strong" signal all the time, so it's always seeing the satellite. I drive an hour each way to work, so it's had PLENTY OF TIME. I tried to reset it by unplugging power to the XM box, and the headunit overnight, plugged both back in, set all my setting back up. Immediately started again, XM music keeps dropping out for "XM Updating" and still can't see the map. I called XM, they sent me a refresh signal to the radio to reactivate it, that didnt work.
I'm using an AVIC-D1 and the XM With navtraffic receiever. All the cables are tight and plugged in etc. Has this happened to anyone else. EXTREMELY annoying.... Trying to use the map today and I couldnt look at it for more than 2 seconds, as I'm hitting okay, it's popping up new boxes, "XM Updating"
:x:x:x:x:x:x:x
Posted Jun 21, 2007 · 00:23 UTC#2
Do you subscribe to NavTraffic? If not, try unplugging the data cable.
Posted Jun 21, 2007 · 01:20 UTC#3
interesting you mention that. I was subsribed to navtraffic, I actually cancelled it about a week ago. Didnt even think about that. Could that have something to do with it ? I saw the navtraffic button in the nav screen was no longer there. Navtraffic was useless to me, becuase it's not supported in my area. All it tells me is that theres long term construction, 50 miles to the north of me where I dont drive anyways.
Posted Jun 21, 2007 · 01:23 UTC#4
yea just leave the IPBus cable hooked up and disconnect the Data cable, all should be well :)
Posted Jun 21, 2007 · 01:23 UTC#5
PS - If you are definitely through with NavTraffic, I'll buy your data cable off of you. I need a new one.
Posted Jun 21, 2007 · 14:45 UTC#6
if your still trying to use the xm and not the navtraffic then u may need to refresh your radio at:
xmradio.com/refresh
i have to do this to my demo unit weekly
Posted Jun 23, 2007 · 18:42 UTC#7
I did the refresh twice. Didnt work I just unplugged the data cable, I have no signal strength meter but I dont care, everything else seems to be working just fine.
Posted Jun 25, 2007 · 04:17 UTC#8
That was a software glitch on the early D1s. If you bitch to Pioneer, they will send you a later version of your software that will fix it. Or you can just leave your data cable unplugged
