no ringer over bluetooth!
By Guest · Jun 24, 2006in Problems/Troubleshooting💬 16 posts👁️ 3,307 views
Posted Jun 24, 2006 · 14:25 UTC#1
Hello. i have the z1 and the bluetooth unit ndbt1. i have a verizon razr. when the phone rings, no ring sound plays over the speakers.
i've tried adjusting the ringer volume in the unit and the phone, and no the phone isnt on vibrate or silence.
the directions for the z1 do say that not all phones will play a ringer over the speaker.
but right now i have no audio indication that i'm getting a phone call, besides the actual phone (if the ring is on)!! any help? if the z1 would play a sound, any sound, when i'm getting a call, that would be great.
Posted Jun 25, 2006 · 13:36 UTC#2
Look at the instructions for your phone. On my LG VX8300, there is an option to transfer the rings to the Bluetooth unit (the Z1) or keep them at the phone. Yours might be the same.
Posted Jun 25, 2006 · 15:41 UTC#3
thanks - but i checked the razr doesnt have that option. :?:
Posted Jun 30, 2006 · 02:08 UTC#4
03Aviator - Where is the option on the VX8300 to get the ringer to work on the Z1??
Posted Jun 30, 2006 · 14:23 UTC#5
I don't know!!! I had my son do it while he was farting around with the system. He works for Verizon. I'll have to ask him. All I know is it wouldn't ring through the Z1 at first. Then he played with it and it does. The manual says you can switch it too....but I didn't check any further because he did it for me.
Posted Jun 30, 2006 · 16:07 UTC#6
I checked the manual, but I was not able to find where the option is....please let me know what your son says he did to get it working...Thanks!
Posted Jun 30, 2006 · 16:28 UTC#7
I know this doesn't help other than to let you know it SHOULD work. I have the v3 RAZR from Verizon - my Z1 rings just fine. Keep plugging!
Posted Jul 06, 2006 · 00:13 UTC#8
I went through every menu option on the VX8300, including the hidden service menu and have not been able to location the option. Any suggestions?
Posted Jul 07, 2006 · 21:10 UTC#9
03Aviator - Were you able to get info. from your son on how to get the VX8300 to send the ring tone to the Z1?
Posted Jul 07, 2006 · 23:49 UTC#10
I have a RAZR and the ringer does come through the Pioneer's speakers. Who is your mobile carrier? Is it the V3 or V3c? Rev 1 or 2?
Posted Jul 08, 2006 · 00:05 UTC#11
I have a Verizon LG VX8300...the same setup as 03Aviator. I tried a different phone with my Z1 and the ringer played over the bluetooth on the speakers. However, my LG VX8300 rings only on the phone. I have read the entire manual and went through every option on the phone without success. What setting did you change on your RAZR?
Posted Jul 08, 2006 · 17:21 UTC#12
i have a v3c verizon razr with 01.15.04 firmware. no ringer!!!
Posted Jul 14, 2006 · 16:09 UTC#13
If your ringer is playing through bluetooth over your vehicle's speakers, please reply the phone model, service provider, and any settings you had to change on the phone to get the ringer to play on the speakers. Thanks!
Posted Jul 15, 2006 · 08:27 UTC#14
Phone: Motorola Q
Carrier: Verizon
The default setup worked for me. I think you can also toggle this feature by going to 1)start 2)bluetooth 3)bluetooth manager 4)Menu --> Advanced 5)select/deselect "Use Hands-free for standard audio".
Posted Jul 16, 2006 · 16:50 UTC#15
Nokia 6600
T-mobile
Ringer over bluetooth works fine
Motorola v600 and v551
T-Mobile
Posted Jul 16, 2006 · 17:47 UTC#16
Check out the phone compatiblity list we're compiling and add your info if it isn't shown there already.
If you don't hear the ringer over your audio system, is the call being connected right away, or is there a delay? You can set if you want the phone to auto answer, in which case it will just connect right when the call comes in.
Personally, I'm not sure I want to hear the ringer, if the music volume drops when a call comes in, it's pretty obvious what is going on (especially with the notification on the display).
