Bluetooth UpdateCD disables flashBypass; fix it on the CD
By AVIS301 · Jun 23, 2007in Hacks/Mods💬 5 posts👁️ 1,169 views
Posted Jun 23, 2007 · 03:00 UTC#1
Does anyone know what files on the upgrade CD from Pioneer I can remove and burn to another Cd; so when i put it in the Z1 unit in my truck it doesn't disable my Flash Bypass?? there has to be a way! If my unit was manufactured prior to July can i use the new bypass instead of the Flash bypass; so that i can use the update CD for the echo problem? Will the new Bypass method void the manufacture warranty? I have a 4 year extended warranty through shity Circuit City. Also i have been getting mixed information about if the Cingular Samsung Blackjack is compatible with the bluetooth adapter?
Posted Jun 25, 2007 · 04:27 UTC#2
Just do the bluetooth update and then do the two wire bypass. If you ever have warranty issues, just don't send in the modified RCA harness with the deck
Posted Jun 25, 2007 · 04:35 UTC#3
I can do the new bypass with the units made prior to July?
Posted Jun 25, 2007 · 04:39 UTC#4
The bluetooth update also changes the bypass to the post-July 2 wire bypass
Posted Jun 25, 2007 · 17:15 UTC#5
Did'nt you ask these questions and get these same answers in another thread?
