D3 Power issue
By flowtime · Jun 23, 2007in Problems/Troubleshooting💬 4 posts👁️ 785 views
Posted Jun 23, 2007 · 20:25 UTC#1
I hooked up my D3 i'm still not exactly sure about the hook up but all the colors matched except for the ILL cord but i plugged everything up and grounded it but it won't turn on.
-I didn't solder the connection.... Is that a must for it to turn on...
-I only plugged up the power and the rca do you have to plug up anything else for it to turn on
Posted Jun 23, 2007 · 20:49 UTC#2
first off what kind of car is it? what brand parts are you using
Posted Jun 23, 2007 · 20:53 UTC#3
It's a 07 Altima and i'm using a metra 70-7552 wire harness
Posted Jun 23, 2007 · 21:06 UTC#4
I finally found my color code chart and it says that the blue/white cord that i have on the wire harness is used for "amp turn-on" and i have it connected to the the ILL cord which is more than likely wrong, but if i disconnected it i have nothing to connect to the ILL wire... Is that okay?
