Moving the mute pin and grounding didn't work. as soon as i drive a screen comes on that says somthing about a ground. anything else i might try. ![]()
Avic D3 Bypass
you did it wrong.
Make sure all the contacts are connecting, and make sure you moved the actual pin for the harness to the correct position. Dont just take that wire and connect it to ground without first relocating it.
why is it so many people have such a problem doing this?
i get mine on tuesday. all you have to do is change mute to slot above it and ground parking break wire right?
for the billionth time, one more time. move mute wire to opposite pin location. ground mute, parking brake and ground wire together. done, its not brain surgery
relax. not everyone lives on this site reading every thread and post.
But everyone can learn how to search. In case anyone hasn't noticed, new threads about bypass problems will be deleted if theres no replies and locked if there are. Got a problem with the bypass SEARCH.
