No Sound on D3
By flowtime · Jun 24, 2007in Problems/Troubleshooting💬 2 posts👁️ 825 views
Posted Jun 24, 2007 · 16:39 UTC#1
I got it all hooked up and it comes on but there is no sound at all
My harness has a blue/white cable that is amp on but i don't think i have any where for that to hook up to so it's not connected to anything
everything else is connected with it mate color but there is no sound from the system
it's a 07 nissan altima with bose
Posted Jun 30, 2007 · 04:14 UTC#2
Heh, I really have no clue what I'm talking about.
You have to double connect the blue/white wire wherever you connected the solid blue wire. In other words, connect the blue wire and blue/white wire to the same spot (wherever that is, I forget). The amp turn on gives power to the audio (I believe?) and it also controls the antenna assuming you have a non-stationary antenna.
EDIT
I went ahead and took a look at mine. I have no clue what I'm talking about :P
Connect the blue wire to the blue/white. Here's a picture. The blue/white is the one on the bottom right.
