VSS wire check
By Melfsterr · Jun 25, 2007in Problems/Troubleshooting💬 3 posts👁️ 888 views
Posted Jun 25, 2007 · 20:35 UTC#1
First time on forum. For the experts out there.
I have a 2003 Dodge DAkota. Just installed a AVIC N1 with N3 software. I haven't hooked up the VSS wire or the reverse lead yet. Is the VSS on a dakota a white/orange stripe located on pin 27 of PCM (middle connector)?
How do I test this lead before hookup to make sure. (I heard that using a volt meter with dial on AC voltage, and looking at meter display while driving vehicle ??)..
Also, do I need to hook up reverse lead if not hooking up a rear view camera............Thankssss :?8)
Posted Jun 25, 2007 · 20:43 UTC#2
Speed Sense white/orange or blue conn. 2, pin 27 @ PCM
Notes: The PCM (Powertrain Control Module) is on the passenger fender.
That's what I have listed for vss. As for testing yeah that sounds about right. No you don't have to hook the reverse up if you're not doing a camera.
Posted Jun 26, 2007 · 13:48 UTC#3
Thanks for the info CNTRYLVR79.
