Guide for installing AVIC D3 in 2006 Corvette-VSS wire help
By thatdood · Jun 26, 2007in Vehicle Specific Wiring💬 5 posts👁️ 1,976 views
Posted Jun 26, 2007 · 00:30 UTC#1
Anyone have experience and/or a guide to install the AVIC D3 in a C6 corvette? I will be installing it withing the next two weeks and I'm trying to prepare. Anything I need to watch out for? I would also appreciate help with locating the VSS wires. I believe it is located under the passenger side wheel well but I want to confirm.
Thanks in advance
Posted Jul 09, 2007 · 13:14 UTC#2
ttt
Posted Jul 09, 2007 · 13:48 UTC#3
Speed Sense dk. green/white cluster or ECM, black plug, pin 57
The ECM (Engine Control Module) is in the front passenger fender. Have to remove the wheel and the access panel behind the wheel to get to it.
Also found in the radio harness on some models.
Posted Jul 09, 2007 · 14:05 UTC#4
BLUE PLUG - PIN #28, AT ECM MODULE BEHIND PLATE INSIDE LEFT FRONT WHEEL WELL TOWARDS REAR OF VEHICLE
I would also look for the same color wire at the cluster. There may be more than one, try pin A4.
Posted Jul 09, 2007 · 19:21 UTC#5
