Hi guys,
Anxiously waiting on my D3 and all its accessories to arrive. However I been thinking.
I have an 2006 300C on 22's by the way. I have a Viper SST remote starter alarm.
What i would like to do, is when you relocate the mute wire and ground the new mute wire and the parking brake, then you got the bypass.
I was going to hook up a relay to my Viper alarm, so that i can remotely turn off the bypass (ie. lets say i get pulled over by the officer, i can press a button and turn the bypass off, so i can show the officier i cant play movies while driving).
How i propose to do this is the following:
Relays have 5 connections:
1. Ground wire for the relay itself
2. Ground wire to feed the mute and parking wire when switch is active (BYPASS ON)
3. Ground wire from the parking brake wire itself when the switch is deactivitated (BYPASS OFF)
4. Switched wire going to the MUTE and PARKING WIRE
5. Postiive feed coming from viper alarm.
Does anybody see a problem with this?
Furthermore, I would like to install a valet switch for when i take my car into service at the dealer, or valet at restaurants. I might use a second relay to tap the accessory wire to remotely turn the unit on and off.
