Avic Z2 Navigation shows moving while stopped
By mattymat · Jun 27, 2007in General💬 12 posts👁️ 2,238 views
Posted Jun 27, 2007 · 22:49 UTC#1
Does anyone have this problem? While I am at a light or sometimes even parked my navigation system will show me moving when I am not. Does anyone know how to correct this problem. Help.
Posted Jun 27, 2007 · 22:51 UTC#2
is the vss wire hooked up properly?
Posted Jun 27, 2007 · 23:02 UTC#3
If you have your VSS wire hooked up, it should stop immediately. If not, then it usually takes 1-3 seconds to stop (assuming you have reception), and probably a lot longer if you dont have reception.
Posted Jun 28, 2007 · 23:18 UTC#4
I think that someone else had this problem here and it turned out that his vss wasn't connected properly. I think that there is usually a sensor wire that detects engine speed. Is it possible that your vss is connected to this wire by mistake? This would show you moving as long as the engine was running.
Posted Jun 29, 2007 · 01:57 UTC#5
VSS makes a night and day difference.
Just connect it coochos! 8)
Posted Jun 29, 2007 · 09:18 UTC#6
I have this problem when my key is in the ignition but the engine is not running, when I turn the key (not enough to start the car but enough to power all the electrical's up) it shows normal. I think the VSS gives a funky reading on some cars when the car isnt running or fully powered.
Posted Jun 29, 2007 · 10:26 UTC#7
What kind of vehicle and where'd you pick up the vss. I've yet to see that problem.
Posted Jun 29, 2007 · 12:17 UTC#8
Its a 2003 Benz, the VSS speed shows perfect when the power is on or engine is running, when the key is in the other position the speed shows like 200km/h or something.
Posted Jun 29, 2007 · 14:41 UTC#9
Sounds like the wrong wire is hooked up or the Vss connection is faulty giving a bad feedback. Check the connection if that looks good double check that it’s the correct wire hooked up. If not sure then unplug the Vss wire and see if it still does the same thing.
Posted Jun 30, 2007 · 15:48 UTC#10
my car is a 96 jeep grand cherokee. The problem with the moving issue while in parked or stopped was not always there. I've had the Z2 installed for about 2 months now and that moving issue has only just started about a week or so ago. How do I find the vss wire for my vehicle to see if it is in fact connected properly or at all? I used to have the N1 and I recall it doing the same thing too. (both were professionally installed)
Posted Jul 16, 2007 · 17:57 UTC#11
I can't guarantee that this will help but it sounds like something called the Chrysler Creep. I had a Siemens VDO Dayton nav system in my Saab 9-2x. The VSS was connected correctly, but the positioner would tell me I'm moving when coming to a full stop. Turns out the VSS signal needed to be modulated. I purchased a sine wave converter that was essentially a square wave converter and used it to filter the VSS signal. Cured the problem instantly.
You may want to ask a professional installer if they've seen this happen with the Pioneer AVIC's.
Posted Sep 06, 2007 · 22:01 UTC#12
Hi, I've an avic d3 installed on a benz c 2002 and I've the same problem. When the key is on ACC, the speed shows more than 200km/h. When I turn the key to on without start the engine, all is ok. When I start the car and when I drive, all is ok. I use a pioneer adapter CA-R-PI.131 which generates speed pulses. Could the problem come from the adapter ? Thanks
