Lanish 62 said:
Thank you for all your help I am going to un ground the parking brake and see what happens.
Well that won't make your "warning" message go away, you need to reset the unit for that.
Lanish 62 said:
If I hook up the parking brake wire what exactly do I hook it to? Or shoulld I not hook it up at all?
It depends on what you want to do. If you plan on flashing your lights every time you turn the car on or you buy one of my circuits, then don't connect it to anything. If you want to use the Z1 like it was intended, then connect it to the parking brake wire like in the instruction manual (kind of complicated to get into here, but there is a good write up in the manual).
Lanish 62 said:
Or if I go with the switch option does that need a power and grownd, and what would I hook that to? The parking brake power?
If you do the switch idea... Get a toggle switch, run the wire from the Z1 labeled parking brake to that switch, then on the other connection on that switch run that wire to ground. When the switch is "activated" and those are connected, that parking brake wire will go to ground. When you flip the swith back, it will not be connected to anything.
You can do that if you want to. Then if you plan on flashing your lights, just turn off the switch (wire floating). If you forget to manually flash your lights, stop and flip the switch. If you start moving and forget to flip the switch back the warning message will come back and you will need to reset your Z1 again.
