Does the Z2 have climate control built in?
By yosarian · Jun 29, 2007in General💬 6 posts👁️ 1,106 views
Posted Jun 29, 2007 · 17:25 UTC#1
I am considering getting a Z2 in my 03 TL to replace my OEM Nav unit. The OEM unit has one feature I haven't seen mentioned here, the ability to control the A/C functions. There are separate controls under the nav forcold, heat, rear defrost and front defrost, however, in the OEM unit, you have the ability to chose where the heat/cold is blowing (feet, feet & chest, chest, etc.) as well as the fan speed. Can the Z2 do this? Or would I am I SOL?
Posted Jun 29, 2007 · 17:40 UTC#2
No.
Posted Jun 29, 2007 · 17:45 UTC#3
Inconsequently it will not work directly you will lose that feature in your car but you can look around online for after market company named PAC they make after market hook ups for this same situation ie steering wheel controls, hvac and so forth
Posted Jun 29, 2007 · 18:05 UTC#4
Great, thanks
Posted Jun 30, 2007 · 04:27 UTC#5
if u got an 03 tl then ur stuck with the factory nav dude.
you might even have one with the first 5 channel surround setup in it in which case it would take alot to make it work
the only thing you can do to those cars is add amps and subs sorry
Posted Jun 30, 2007 · 13:52 UTC#6
Damn. I could remove the double din Bose radio & cd changer combo and put it in there, but I don't like the idea of having to look down at the nav vs looking to the right when driving.
I should have gotten one without the nav. If I did, I would still be driving around Georgia looking for the on-ramp.
