Iphone
By nodnarb901 · Jun 30, 2007in iPod/iPhone/iPad💬 7 posts👁️ 3,820 views
Posted Jun 30, 2007 · 12:40 UTC#1
Just wondering if you can plug up and iphone to the Pioneer ipod adapter and still listen to all of your songs through the avic d1? Don't want to do anything else through the adapter just listen to music.
Posted Jun 30, 2007 · 17:13 UTC#2
Yes music does word with the D3.
I'll write up full details later today.
Posted Jun 30, 2007 · 20:40 UTC#3
Ok heres what I have found.
The D3 and the iPhone will work but VERY limited.
You can play music on the D3 with the iPhone but there is no way to get the video output to work. Also the D3 will not charge the iPhone.
I don't have a bluetooth connection for the D3 so I cant check the phone connection but I would assume it should work as it is just bluetooth.
My hopes are they will give us a new DVD with an update for the D3 so it will better support the iPhone.
I tried a few work arounds to get the charging to work but none of them seam to actualy charge the iPhone.
Posted May 11, 2008 · 13:59 UTC#4
The bluetooth works perfectly fine with the iphone. The only thing is if you are listening music and someone calls you and that person ends the call, the d3 will resume the song previously be played, but if you end the call it will resume the song for 3 secs and then it'll stop playing. You just need to press play on your d3.
Posted May 17, 2008 · 18:12 UTC#5
well i know for a fact the d3 does charge the iphone. there is a box you can check if you want to turn charging on or off. i dont understand why it wont play the video off my iphone. as for ending a call when someone calls, it does but as soon as i hang up it resumes. there is a setting on the iphone to change it.
Posted Dec 30, 2008 · 02:38 UTC#6
Where is this box that would allow me to charge my 2G iphone w/the D3? I get the "accessory" error message when I hook the iphone up to the D3 using the ipod connector. I also read that the D3 would fry your iphone.
Thanks for the info.
Posted Dec 30, 2008 · 13:54 UTC#7
After recieving that "accesory" message this morning, I got the iphone to work thru my D3. The only thing it will not do is play video from the iphone. :x
