Hi all,
New to the site and must say I've learned allot so far... I installed my AVIC-D3 yesterday in my '04 tacoma double cab and have run into a problem. Everything appears to be working fine (even the bypass) except that it blows my gauge (tach, speedo, etc) fuse when I shift into reverse. I rechecked the wiring and there are no pinched spots in the wire and is wired correctly per the Toyota wiring info I have. I tested the wire before hand as well to verify that it was the reverse. I'm not an expert by any means so, I must have goofed somewhere... Any ideas???
Thanks in Advance,
Austin
