VSS in a 94 Full Size Blazer
By steve310 · Jul 03, 2007in Vehicle Specific Wiring💬 3 posts👁️ 797 views
Posted Jul 03, 2007 · 00:03 UTC#1
Directwire says green wire at the ECM, and there are about 5. Tested all of them and the only one that seems to have a chance of being right gives me about .5 volts when stopped, and just over 13 volts when moving. Theres almost no transition. Is that the right wire? Its the first time I'm wiring into a speed sensor so I'm not sure. It just seems like voltage should increase with speed.
Thanks in advance...
Posted Jul 03, 2007 · 00:12 UTC#2
voltage doesn't increase with speed. The fequency increases with speed. Though what you tested sounds about right for an older gm truck.
Posted Jul 03, 2007 · 00:45 UTC#3
Thanks, just to be sure I"ll check the frequency tomorrow
