07 Santa Fe SE VSS + Reverse
By Toriba · Jul 03, 2007in Vehicle Specific Wiring💬 6 posts👁️ 2,661 views
Posted Jul 03, 2007 · 17:47 UTC#1
Hi,
Rostra gives the location for the VSS, but says it is the same as on the 06 Santa Fe. Since the 07 is a totally new car, I think that may be wrong.
If anyone can confirm the VSS and reverse locations on the 07 Santa Fe it would be a huge help. Thanks so much!!!
Posted Jul 03, 2007 · 18:35 UTC#2
Speed Sense is the brown wire at the data link connector, pin 6.
The data link connector is under the driver side dash.
Also found at the BCM, 16 pin plug, pin 6. The BCM (Body Control Module) is under the driver side dash, behind the fuse box.
Thats for the 07, the 06 doesn't give the BCM option.
Posted Jul 03, 2007 · 18:38 UTC#3
Thanks, steve310!
Do you know if I can pick up the reverse wire at that fuse box, too?
Posted Jul 03, 2007 · 19:10 UTC#4
Yep, Reverse Light is the blue wire at the fuse box, red 16 pin plug, pin 4
Posted Jul 09, 2007 · 01:51 UTC#5
Put everything in this weekend using the wiring information above. Worked like a charme! The Navi is very accurate with the VSS hooked up. Thanks again for the help!
Posted Jul 09, 2007 · 02:12 UTC#6
You're welcome, glad everything worked out
