Okay, I have the wiring Harness, z2, antenna adapter. Where do I find the VSS and reverse and parking break wires? Is everything else basically plug and play?
Help!
Help!
Reverse Light black/blue + driver kick, harness to rear
Parking Brake brown/yellow - parking brake switch
Speed Sense blue/white instrument cluster, blue plug, pin 3
Can someone tell me where I can find the VSS wire on a 2000 VW Jetta? I've read from the12volt.com that it is located on a 3-pin connector off of the transaxle. I've also read elsewhere that it can be found on a 32-pin connector in back of the instrument cluster? Is this correct and will it be difficult to get to? Is there an easier way?
