2005 F350 Parking Brake Wire
By Scooter_Alberta · Jul 05, 2007in General💬 6 posts👁️ 1,322 views
Posted Jul 05, 2007 · 00:46 UTC#1
Just about done the install on the Z2, but having problems locating the parking brake wire. I did read some where that its the lt green/red or just lt green, can anyone verify for me please.
Scott
Posted Jul 05, 2007 · 02:15 UTC#2
On my 2004 I picked it up at the switch. I am unsure of the color. I just used a multi-tester and checked it. You have to use the switched side. Just check one side with the parking brake off. Ground one lead of the tester and put the other on one wire if you get continuity then check the other wire. That should be the wire to tap into. You should only get continuity on that wire with the parking brake on.
Posted Jul 05, 2007 · 02:45 UTC#3
Parking Brake lt. green/red - switch or cluster, blue plug, pin 18
Posted Jul 05, 2007 · 03:18 UTC#4
Switch or Cluster Blue plug pin 18? I'm sorry I don't know what that means, is that a blue plug into the fuse box, I don't think so as none of them are blue. I followed the ground, and and it's meets 3 other wires that are all taped up, can you give me a little direction as to where the light green/red wire is.
Posted Jul 05, 2007 · 03:22 UTC#5
if you look at your paring brake. at the top of the assembly, there should be a single wire connected to it with a large black plastic connector
Posted Jul 05, 2007 · 16:53 UTC#6
Got it,
Thank you
