07 ford e250 van
By brianas · Jul 05, 2007in Vehicle Specific Wiring💬 6 posts👁️ 1,789 views
Posted Jul 05, 2007 · 01:15 UTC#1
need vss wire, reverse wire
thanks
Posted Jul 05, 2007 · 02:48 UTC#2
Reverse Light black/pink + driver kick, harness to rear
Speed Sense gray/black ac PCM, top plug, pin 1
The PCM is under the hood, next to the brake master cylinder.
On diesel vehicles, the VSS wire is in the top plug, pin 22.
make sure its not in the radio harness first
Posted Jul 05, 2007 · 12:18 UTC#3
ok thanks for the info,
have you put a dbl din in a ford van yet?
thanks
Josh
Posted Jul 05, 2007 · 12:52 UTC#4
yeah, i've done a lot of fords
Posted Jul 13, 2007 · 03:34 UTC#5
Double-din is not a problem, just make sure you tie everything up behind the dash, the wiring and other behind-the-scenes objects have a tendency to fall out of the dash above the doghouse(motor cover). Noise filters are not meant to be seen OR heard.....
Posted Oct 13, 2007 · 15:08 UTC#6
forgot to post back on this one,
never found the VSS , apparently things changed
for wiring for 07 --rev found as posted- thanks
the sub dash must be trimmed down on the vans radio
opening to fit dbldin
also i had to fab brackets to mount the unit- there is no
factory brackets or anything in there- its just empty
and wide open
thanks
Josh
