D1 - GPS OK, no satellites
By cefoskey · Jul 05, 2007in Problems/Troubleshooting💬 6 posts👁️ 1,061 views
Posted Jul 05, 2007 · 03:11 UTC#1
Ive had my D1 for about 2 years which it has worked flawlessly. About 4 months ago a body shop mangled my antenna so I had to replace it with a new one, which has also worked fine since then.
Just today for some reason I noticed the NAV drifting off course and went to connection status to see no satellites connected, but an "OK" status. Ive tried relocating the antenna all over the place with no luck. Ive also tried a few resets, also with no luck.
Is this just a bad antenna already?
Posted Jul 05, 2007 · 17:53 UTC#2
probably a kink or internal break in the antenna wire.
Posted Jul 10, 2007 · 13:42 UTC#3
Well while driving the sattelite link now works occasionally. It will track properly then lose all signal and go off course, but with the antenna status remaining "OK". It seems totally random at this point.
Posted Feb 15, 2008 · 20:19 UTC#4
i have the same problem, have you figured out the cause?
Posted Feb 15, 2008 · 23:17 UTC#5
Posted Feb 16, 2008 · 01:39 UTC#6
OK just means that the deck sees something plugged into the antenna hole. Doesn't mean that its working properly
