Okay, so I've spent all freakin day installing my z2 into my 2003 Jetta. Everything is hooked up except for the brake wire (Im going to just ground it I think). I used the wiring harness that came with it, and now the unit comes on as soon as I plug into the harness, and will not turn off by the key, I have to manually unplug from the back of the unit. How do I fix this?
Also, What mounting bracket can I use to make this unit look flush and great? Thanks! Please be specific as Im a beginner on installs. Thanks!
