has anyone used nero to make a background????
By tyscamry · Jul 05, 2007in General💬 6 posts👁️ 1,105 views
Posted Jul 05, 2007 · 23:43 UTC#1
I just downloaded Nero to burn my pic to a cd so that I can upload them into my Z1 and the Z1 states that I must make a pictures folder when I press the import pictures. I know how to make a folder with windows vista but not with nero. I found out about nero on here but noboby said how to make a folder. Please help me if you know how. thanks.
Posted Jul 06, 2007 · 04:51 UTC#2
I use nero, I make a "Data" Disc, and make sure that Nero finishes the session after each burn so no other data can be added, unless you erase your CDW-R
First on your desktop create the "Pictures" folder put the JPG files in there.
Then simply drag that folder in the Nero
Posted Jul 06, 2007 · 04:54 UTC#3
in vista create folder called pictures and add your files into it. Drag folder into nero and burn the folder with contents.
Posted Jul 06, 2007 · 06:01 UTC#4
on this same note has anyone had a "data read error"
on my pics discs of 20 pics each usually 5 of them will say the above
the other files that are the same size will work fine any ideas?
Posted Jul 06, 2007 · 10:52 UTC#5
Its the way that the JPG's are saved. It's in another post somewhere, but when you use adobe photoshop and save the jpg's if you just do a "save as jpg" it will not work with the Avic, and give you a read error. If you do a "save for web page" it will work fine. I think that MS paint, if you open the jpgs and then save them from inside that program it will work as well.
I don't know exactly what part of those image files the Avics don't like but you just need to "save them correctly".
Posted Jul 06, 2007 · 19:06 UTC#6
I using nero photo shop deluxe and I try to drag it over and it didn't work at all, what I'm I doing wrong. I went to the manage and make section and I even try to copy and paste and that didn't work. How do you make it work step by step would be helpful to me.
