who knows the proper way to recalibrate touchscreen?
By petershin_95 · Jul 07, 2007in Problems/Troubleshooting💬 3 posts👁️ 1,252 views
Posted Jul 07, 2007 · 19:06 UTC#1
on the left side of my screen when i touch it, it thinks im touching about an inch to the right.....
does anyone know the right way to recalibrate the freaking screen?!!!
i followed the direction on the bottom, and it does not work!
im so fed up with pioneer products failing and having problems, now wonder why alpine is #1
Posted Jul 12, 2007 · 04:14 UTC#2
i'd say send it back if you just got it! call pioneer to see how you can fix it or have it replaced... Call (800) 421-1404. good luck!
Posted Jul 12, 2007 · 07:12 UTC#3
Follow the instructions by REMIX2112 posted Nov 2006. I just did it today and it worked. I learned that all you have to do is press (EQ) button and then (BAND) to go back in the menu. If you are off alot, I found that all need to do is not trace the outer white line. Just place your pointer a cm from the side. I just used a pointer once at the bottom and once at the top. The values changed ok. **It took me 3 times to figure it out.**
Save your money...
