Speed sense wire on a WRX
By Guest · Jun 27, 2006in Problems/Troubleshooting💬 4 posts👁️ 1,106 views
Posted Jun 27, 2006 · 13:29 UTC#1
Does anyone know which is the speed sense wire on an 03 Subaru WRX Impreza? I thought it was hooked up right but I am not getting ant readings from it.
Thanks.
Posted Jun 27, 2006 · 13:35 UTC#2
Did you look in the How To section here and try that?
Posted Jun 27, 2006 · 13:54 UTC#3
green/yellow at ecm below glove box
On the non-turbo models the vss is in pin 10 of the 20 pin plug. On the turbo models the vss is in pin 1 of the 22 pin plug.
The vss wire is also found behind the instrument cluster in the 10 pin plug.
Hope this helps
Keith
Posted Jun 27, 2006 · 14:14 UTC#4
Thanyou very much for the help. I will check it this evening.
Thanks again.
