Help. Route doesnt appear to start! - New Z2 install
By rdkl · Jul 08, 2007in Problems/Troubleshooting💬 6 posts👁️ 1,075 views
Posted Jul 08, 2007 · 04:30 UTC#1
Everything seems to be working except for my navigation. When I try to navigate somewhere I go through all the motions and after I hit ok it does show the route on the map but I do not get any prompts (neither voice nor on screen) for turns nor does it care if I go off route.
I am at a loss as to what is happening at this point. I have been through the manual and all of the menus and I cant find anything I am missing.
Also, when I am supposedly using navigation, the two map views for route guidance are not available (manual says these 2 only become available when on a route).
Any ideas? I did doublecheck my wiring. I saw some weird readings from the VSS so I have tried removing that wire and so far am still seeing the same behavior.
Posted Jul 08, 2007 · 04:35 UTC#2
Since you've disconnected the vss, try resetting the learning status on the system. Also in the connection status menu make sure you're getting a gps signal. As for the voice prompts and stuff, it may sound stupid, but make sure it's turned on.
Posted Jul 08, 2007 · 04:41 UTC#3
Thanks for the quick reply. I went ahead and gave that a shot. Still no go. All the levels are correct as well.
It never seems to actually start the route. I still cant view the route view or the other option.
I am starting to think I may have been given a bad unit :(
Is there anything else to be done when routing after you view the route then hit ok?
Posted Jul 08, 2007 · 04:43 UTC#4
Nope, just drive to the greenish line and start driving on the route.
Posted Jul 08, 2007 · 04:44 UTC#5
That could be my problem. It never seems to show me on the road but rather just near it..
Posted Jul 08, 2007 · 18:08 UTC#6
That solved the problem. Guess I'll need to find a different location to get vss from!
Thanks again!
