A few questions about the D3....
By venom33 · Jul 08, 2007in General💬 7 posts👁️ 1,434 views
Posted Jul 08, 2007 · 21:34 UTC#1
Im new to the site so hello to all....
I have a few questions concerning the d3. this will be my first navi system so if the questions are ignorant my apologies.
1)can you hookup an xm receiver and a cd changer to the d3 at the same time or do they use the same outlet?
2)the d3 will be going in a 04 dodge ram and the install will have to be custom, has anyone else installed a double din in a dodge ram? if so did you run into to any issues with the install?
Posted Jul 09, 2007 · 04:15 UTC#2
Yes, you can connect both.
Use the search function and you will find Dodge installs.
Posted Jul 09, 2007 · 15:47 UTC#3
I just installed one in my 07 Dodge Ram, but I realize the dash is a bit different in 04. You can see a picture in the gallery.[/img]
Posted Jul 09, 2007 · 21:17 UTC#4
thanks for the info...
one more question, can i have both xm and sirius at the same time on the d3??? does it matter the model of each?
Posted Jul 10, 2007 · 14:44 UTC#5
You can run both at the same time, I'm guessing you would have to have one of the Pioneer XM units to make this work since the Sirius data connection travels through the XM interface. I'm not sure about the Sirius hardware tho.
Posted Jul 10, 2007 · 19:04 UTC#6
I have both XM and Sirius on my D3. You can have both with no problems. Just follow the hook up directions in proper sequence and you'll be fine. XM has a better interface but the Sirius improved GREATLY from when I had my N1.
Posted Jul 10, 2007 · 19:29 UTC#7
search for "installs in kansas"
theres a dodge with your same dash on there yes it is a custom job. (hight needs about 1/4 inch and then the round pieces need to be filld in.)
not too tough a job but i will need painted if you want it to look good
