What dO I need to install a D3 in a Saab 9-5?
By devioustrap · Jul 08, 2007in General💬 3 posts👁️ 995 views
Posted Jul 08, 2007 · 23:18 UTC#1
I've been researching the AVIC nav systems for a few days, but I can't seem to figure out concretely what I need to install the system. Is there any special dash kit, or will the system just cleanly go into (what I presume is) the standard double din opening where the current radio is.
Also, as far as connectors do I need something like this?
Any help would be appreciated. Thanks.
Posted Jul 09, 2007 · 04:14 UTC#2
You might need a trim piece to go around, if you can't find a double-dash kit, go to a reputable shop in your area and have them take a peek.
Posted Jul 09, 2007 · 23:38 UTC#3
I have the D-3 in my 2002 9-5 Aero. What I did was cut off the back of the existing cage and drilled holes in the side of the cage to align with the tapped D-3 holes.
As far as cabling I soldered the D-3 cables to the adapter provided by Crutchfield. My Aero has the Harman Kardon Prestige sound with an amp so I soldered RCA plugs to the respective lines in.
I have attached a spreadsheet with the color codes.
I had an amplifier thump when turning the radio off which was eliminated by installing ground loop isolators in the audio lines.
Another guy on this board installed a D-2 in a 9-5. If you search for Saab you will find his and my experience as well as some photos.
Good luck and please let me know if you need more help.
AVICD3_AERO_HEADUNIT.xls
