I'm buying this from a guy but the antenna is not w/ it. I have an antenna from a Roady2 XM radio I previously used. Will the regular magnetic Roady2 antenna work w/ this XM receiver?
GEX-P910XM antenna HELP please
does no one know the answer to this? a car stereo shop nearby seemed ignorant when i called them so i wanted to check with you guys.
Should work just fine. As long as the receiver doesn;t have the yellow and green connectors. Ever if it did you would just need an adapter. Ive used a roady antenna on my car with no problems.
If the roady antenna has a purple connector then you should be fine, if its a black connector at a 90degree angle you need an adapter which comes in the micro xm antenna packaging.
know where i can get this adapter? i remember seeing it when i bought the roady but have no idea where it is! i knew this would come back to haunt me
will this work??
http://www.circuitcity.com/ccd/productD ... =DATAFEED->PRODUCTS&cm_ite=1%20PRODUCT&cm_keycode=4
Should be perfect!
thanks gents
Actually you will need this as well...I don't have the url but go to www.xmfanstore.com and then look for this....XMFanStore XM-1DAS XM Radio Antenna Splitter. Or just get a new tuner! ha
I have an old dual output antenna that'll work with your tuner. PM me your address, and I'll let ya know how much.
so the regular magnetic antenna from my Roady2 will work on the gex-p910xmt? i see that it works on just the 910xm...wasnt sure if the nav traffic model would be any different.
i picked up the nav traffic receiver for 90 bucks shipped but it was missing the antenna. was that a good deal or should i have looked elsewhere?
