Metra 70-1771??
Metra 70-1771??
is it an eddie baur edition? if so you may need the amp integrator harness.
if not the the 1771 will work fine
Perfect, thank you!!
it's either 70-1771 or 70-5700 if you have the premium sound.
nope, no premium sound
Good old 1771 ![]()
fyi I bought several different harnesses specific to the 00 expedition eddie with prem sound and none worked.....The pins just didn't match up accordingly.
I ended up having to use couplers and patching directly onto the factory harness using the colors accordingly....
Also, If you have an expedition above 99 beware.....Once you remove the factory radio there is so much more involved, really! Ontop of the metal cage you need to alter a little bit, the new expeditions have a really strong plastic like frame that you will need to cut a bit off off from the top for any avic double-din to fit.......Took me four hours to do so, but I did....
Four hours of cutting into metal and plastic!!!! But so worth if for the avic-d3
does anyone know which one i'd need? i have a 99 eddie bauer expedition with premium sound. thanks
