How do I route between DVDs?
By Vman · Jul 12, 2007in General💬 6 posts👁️ 1,097 views
Posted Jul 12, 2007 · 20:41 UTC#1
I live in Pennsylvania and will be going on a trip to Ohio. The maps for Pennsylvania are on one DVD and Ohio is on the other.
If I put the Ohio DVD in to find the address and then put the Pennsylvania DVD back in, will it automatically route me across the two states?
Thanks.
Posted Jul 12, 2007 · 22:08 UTC#2
these should be both on the same dvd? Anyways, just touch the region you want to go to on the disc and it should route you there because it knows where you are at currently.
Posted Jul 12, 2007 · 22:11 UTC#3
I'll double check. When I do an address search, Ohio isn't one of the states listed. Maybe I have to modify the region or something.
Posted Jul 12, 2007 · 22:25 UTC#4
From what I understand, you do the search for you Ohio Address with your current disc. Once you are actually taking the trip and cross into the part of the US that the other disc has, then it will ask you to put in the other disc.
Posted Jul 12, 2007 · 22:28 UTC#5
Oh, also make sure that when you go into the address search screen, you select Ohio as the state you are searching the address in. When I first started using my D3, I was searching for an address in Washington. That 800 mile route that popped up surprised me.
Posted Jul 15, 2007 · 03:35 UTC#6
Ok. Figured it out.
When you go to type in the address you're searching for, you can select the little number (current region) in the top left hand corner of the screen. There's no label or symbol for it....just a number. This allows you to change which states you'll be searching in. I chose the region that contains Ohio (I think it was 6).
I then typed in the address and started driving. Since the D3 already knows I'm currently in PA, it was able to route to the Ohio address from Pennsylvania.
Kinda clunky but it works.
