Improper connection of parking brake lead
By shacall · Jul 13, 2007in Problems/Troubleshooting💬 20 posts👁️ 19,700 views
Posted Jul 13, 2007 · 02:44 UTC#1
Hi,
I just installed my D3, and *thought* I followed the bypass instructions to a tee. The second I start to drive, the following message pops up:
"System detected improper connection of parking brake lead"
Obviously I did something wrong with the parking brake wire, but I'm not sure what. It seemed simple enough - just ground the green parking brake wire coming from the D3....correct?
I used these great instructions:
http://www.avic411.com/D3Bypass/album0.html
and tapped the green wire into the ground cable. The ground cable is grounded to a bolt that goes into the dash frame. Could it just not be properly grounded, or is there something more complex that I'm missing?
Posted Jul 13, 2007 · 02:45 UTC#2
did you move the cell mute wire and ground that?
Posted Jul 13, 2007 · 02:55 UTC#3
If that's the yellow wire on the AV plug that is moved from the lower hole to the upper hole...then yes, I did do that. Does that ground it, or is there another wire that needs to be grounded?
Many thanks!
Posted Jul 13, 2007 · 02:58 UTC#4
after you move it hook it up to the same place the green wire is. I could have sworn the instructions said that.
Posted Jul 13, 2007 · 03:08 UTC#5
That might be the problem. I was going off these instructions:
which say to just move the plug up a hole. Am I supposed to ground the mute wire with the green one?
Posted Jul 13, 2007 · 03:24 UTC#6
yes
Posted Jul 13, 2007 · 03:46 UTC#7
Thanks for the help - it's very much appreciated. I'm going to wait until next weekend, before I attempt the bypass again. It's too painful to remove the entire dash :? Next time, I'm driving it without the dash reinstalled...just in case (don't ask me why I didn't do that in the first place).
Anyway, thanks a ton! Hopefully, that'll resolve my problem.
Gary
Posted Jul 13, 2007 · 03:50 UTC#8
I think I know what I did now. I bought a toyota harness, which has all of the matching colors...including the yellow/black. I moved the yellow/black wire pin up, but soldered the other end to my toyota harness. Looks like I need to break that connection and ground the end coming out from the D3...correct?
Posted Jul 13, 2007 · 04:26 UTC#9
What did you solder the mute wire to on the toyota harness?
Posted Jul 13, 2007 · 04:37 UTC#10
I don't really know for sure if I soldered it to a yellow/black wire on the toyota harness, or if I left it alone and it's just dangling there. I need to rip off my dash to determine what I did.
However, it's a guarantee that I did something very stupid :lol:
Posted Aug 24, 2007 · 23:46 UTC#11
Did you ever get this figured out? I am getting the same message on my D3. I did nothing with the mute wire. Everything works fine but I still get this message on startup. I installed in a Toyota Tundra. I don't understand what the mute wire has to do with anything.
Posted Aug 25, 2007 · 02:41 UTC#12
You need to move the yellow/black (mute) wire in the Pioneer harness to the other hole (to contact ahidden circuit inside the D3) and then ground it to complete the bypass. That's how it works, and that's what the mute wire has to do with it.
Posted Aug 25, 2007 · 03:00 UTC#13
So by moving the mute wire and then grounding it I will no longer get this message: "System detected improper connection of parking brake lead"
at startup? Thanks in advance for clarifying this.
Posted Aug 25, 2007 · 03:34 UTC#14
Exactomundo.
Posted Aug 25, 2007 · 10:44 UTC#15
I just pulled my D3 out of the dash to reroute the mute wire and found that I am not using the white plug shown in the tutorial. I am using the black plug. I purchased this stereo from Best Buy as an open box unit and it did not unclude the white a/v in/out cable. Should it have? Is there a mute wire on the black a/v in/out cable? Where can I reroute this to? Someone please help me out here. Thanks.
Posted Aug 25, 2007 · 12:25 UTC#16
Should it have?
It was open box, so technically they didn't need to give this to you, but yes it is needed to bypass.
No
Reroute the mute wire? You need a white harness.
Thanks.
You're welcome.
Posted Aug 25, 2007 · 12:33 UTC#17
Thanks, I will go to Best Buy today and demand that harness. I don't know why I buy the open box deals. I always screw myself!
Posted Aug 25, 2007 · 13:42 UTC#18
Is the whole the open box discount based on the fact that pieces are/could be missing? I don't think you're going to have a very easy time demanding anything from them...
Posted Aug 25, 2007 · 17:52 UTC#19
Well, I got lucky. They had the cable in the back. Don't know why it wasn't in the box but anyhooo....I got the cable. By the way, I asked the service counter what the policy is with an "open box" and if it is missing cables and they told me that if it is missing cables, they will open another box and give me what I need.
I'm on my way to pulling the stereo out one more time. Next issue is getting the stereo to see a CD-R with pictures on it. It keeps telling me that I don't have a pictures directory on the disk when I know for a fact that I do. :?
Posted Aug 26, 2007 · 05:10 UTC#20
Haha, their policy is to sell an open box item, then open another box to steal any missing parts? Then they sell that open box, until they find someone who doesn't notice the missing piece, I assume. Or maybe just return it back to the manufacturer as incomplete. Glad it worked for you, but that just seems wrong.
