hey i just got the z2 a few weeks ago and i was fooling around with the settings and saw that you can import pics from a cd and make it your background. i read up in the manual and followed all of the instructions to a T, but when i put the cd of pics in, all it says is "CD-ROM inserted". and it won't read the cd...any ideas??
importing pics from cd to the z2
Did you actually go to the menu that lets you choose the pictures in your disc or did you just assume that when you pop in the disc it's automatically going to take you there?
yeah, i went to the menu and the "Import from disc" button wasn't highlighted.
for the raw data just use .zip files that equal >100mb. And you have a "pictures" folder. Should be good to go after that!
Posted: Sat Jul 14, 2007 7:17 pm Post subject:
i'm sorry but i don't really understand what you mean. i have a "pictures" folder. should the pics be in a .zip or what? im confused.
what he is saying is that you have to have your pictures in a folder title "pictures"
then you also have to make a junk folder, full of a bunch of other "junk". just make sure it doesnt have any audio files, and that the total disk space used ends up over 100MB.
this is all in your instructions, so I am sure you did this part correctly.
the other thing that caused me problems, was using the windows software to burn the disk.
for some reason the avics dont like windows burning software.
I downloaded a free trial of Nero, and it worked first try.
yeah i did all that, but like you said i used windows to burn it. ill try nero and see if it works. thanks alot!!!
sid06...I'm wondering if you ever had any success with your background pics? I'm having the exact same problem that you described. I downloaded a trail version of nero 7 (to be exact). Created the "picture" folder with over 100MB of "junk" data. Burned the cd-r as per instructions in the manual (mode 1, no multi-sessions and finalize). Still, all I get is CD-ROM Inserted. I go to the menu to change background and the"import from disc" is grey and not allow me to select it as an option. What was your "secret to success"? I thought that I was going all the way into the menu to change the backround setting but maybe I'm not...HELP!!!!
calvin1202...yes i was successful in getting the picture background to work. just do exactly what bigred said and it'll work fine. for some reason it doesn't work with windows, so use nero. nero works like a charm for the avics. after you put the disc in, go into the settings menu, then background, and the "import from disc" button should be highlighted.
when i imported the pictures to my avicz1, the picture is not displayed full screen. my picture was resized to 500x240. am i missing something?
can i store my pictures to my avicz1 HD?
thank you.
This doesn't work, period. I consider myself very knowledgeable with all CDR burning programs and I ruined 10 CDR's using everything from Windows, Roxio, to Nero and this simply doens't work and it's fu*king annoying. I did EXACTLY what the guy said up there and the import from disc is still greyed out no matter what.
are you creating a "pictures" folder (well that's how it is on z1, not sure what you have to call it for the z2) and also, i used a CD-RW for my pix...
info from Z2 manual:
Limitations for importing pictures
When you burn a CD-R (-RW), make sure the
total data size of the CD-R (-RW) is greater than
100MB by storing dummy data or other filler
information. Otherwise, the disc may not be
recognized by the built-in DVD drive.
❒ You cannot use a CD-R (-RW) containing MP3
files or Audio data (CD-DA part) for importing
pictures.
❒ When storing pictures on a CD-R (-RW), create
a folder named “Pictures†in the CD-R (-
RW), and store the picture files in this folder.
(Up to 200 picture files can be used in total,
including pictures that are already stored in
the hard disk drive and pictures in the CD-R (-
RW).)
❒ When you burn a CD-R (-RW), limit the number
of folder hierarchy levels to eight.
❒ You can only use a CD-R (-RW) finalized with
single-session for importing pictures.
“Mode1†for importing pictures.
❒ Only JPEG format (“.jpg†or “.JPGâ€) pictures
can be used. Progressive format JPEG pictures
cannot be used.
❒ Using only the standard Latin characters
(alphabets of both cases: A-Z, a-z) and numbers
(0-9) is recommended for the file name. If
you want to use letters with diacritical marks
(such as ä or è) for file name, finalize the CDR(-
RW) with Joliet (Unicode) format.
❒ Pictures up to a maximum of 2 592 x 1 944 pixels
can be used. We cannot guarantee proper
operation for a picture bigger than this size.
❒ After changing a set image that was imported
from a CD-R (RW), you must use the CD-R
(RW) where the image is recorded to restore
the previous Splash Screen.
Did everything on that list, nothing works.
