So who else hates the delay between tracks?
By noreaga0221 · Jul 17, 2007in General💬 8 posts👁️ 1,339 views
Posted Jul 17, 2007 · 02:22 UTC#1
And is there anyway to fix it?
Posted Jul 17, 2007 · 03:57 UTC#2
What media are you talking about?
Posted Jul 18, 2007 · 00:32 UTC#3
Music, cd-r's and dvd+r, mp3s, aac,wma.
Posted Jul 18, 2007 · 00:37 UTC#4
Burn them without a pause between tracks
Posted Jul 18, 2007 · 00:46 UTC#5
It it because they are burned as data? For some reason nero wont burn wma and mp3 to the same cd.
Posted Jul 18, 2007 · 16:52 UTC#6
Just a theory:
You may want to check your burning software and make sure you didn't check (or it isn't by default) the "insert 2 second gap between tracks" function. It doesn't seem like a long time, but if you add 2 seconds to the gap that is already present between tracks, it will be noticeable.
Posted Jul 20, 2007 · 16:06 UTC#7
If you are burning data files directly onto a removable media, then it may be that the actual song has a pause at the end.
Posted Jul 20, 2007 · 16:10 UTC#8
Ahh, ok. You are burning audio tracks onto a removeable media. As the others have suggested, you have to go into the properties of each track and change the settings.
You can also just burn the files as data as the D3 will play mp3 files. I haven't tried wma files.
