ok so i used a hair dryer and got the sticker on the back off with no trouble but im not sure what the switch looks like or how to tell if its in the right position or not. i seen the picture that someone else posted but im still not clear on how to do the switch...this is my first navi so please help me out...i get it installed on thursday,,,thank you all
i need avic-n3 bypass help please
http://www.avic411.com/forum/viewtopic.php?t=3153
Its a switch, so it slides from side to side. Take a paper clip or something and slide it to the opposite side from where it comes from the factory
where do i insert the paper clip tho? on top of the shiny piece or on the side? cause i dont really see anything that resembles a switch or that will move.
You put the paper clip in the giant hole that is exposed when you remove the sticker. There is a little black switch that is sitting there against the circuit board. If you look at the picture on the other thread, there is a white outline (on the actual circuit board) of where the switch should be sitting from the factory. Kinda like a chalk outline. Move it over to the other position
ok so that switch is very tiny then right and it is resting between the circuit board and the chrome piece?
one more thing for the green parking brake wire...should i ground it to something metal in the car...i.e. a bolt or the frame..or just o the ground wire for the car?
damn havin the worst time tryin to bypass this i probably already did just dont know it...i took the sticker off again and i looked in the little black slit above the chalk line but i dont see anything that looks like a switch...it just looks like a slit with nothing in it.
aight i got the switch done...i ended up already having it switch but i used a safty pin to seitch it back to see if i was doing it right...i appreciate your help. hopefully frys will help me out tomorroew when i get it installed with the parking brake wire.
Yea ground that parking break wire where ever...I usually just tie it into the vehicle harness.
