anyone use these? Like that are found on eBay?
Screen protectors?
I got one. Works fine. Just a thin film that covers the screen. eBay was cheaper than any store here in the are. Just take care when peeling the film from the backing. It tends to rip easily if no care is taken. Otherwise, go for it.
shieldzone.com they are the best.
what size would i get for the Avic D3?
You can order a "custom size" which is 9inX3.75 inches cut it to size. I've got these skins on two blackberries, two Ipods, and a few other small work related electonics. They are the best I've used and probably some of the cheapest.
If they do not have a listing for that radio, you can customize the size just measure it and give it to them.
ya there's no listing for the D3. anyone have the exact measurments or i'll just do it myself!
thanks!
just make sure you clean the screen very well and use a can of air.
ANY particle under it will bubble and look bad.
maybe I'm just OCD....
Exact mesurament according to the manual:
136 mm x 72 mm
Thanks a lot!!!
P.s. how many of you actually have screen protectors?
Do you like it? Does it hinder the touch screen or the look of the screen at all?
If done correctly, you can't eve tell there's one on. But as mention before, clean it very well prior to install.
