2005 Mazda 3i - VSS Wire
By adidasfanatic · Jul 18, 2007in Vehicle Specific Wiring💬 5 posts👁️ 1,199 views
Posted Jul 19, 2007 · 00:52 UTC#2
Speed Sense WHITE/RED OR WHITE/BLUE (AC) PCM PIN 1J
Posted Jul 19, 2007 · 14:41 UTC#3
Thank you!
Posted Aug 05, 2007 · 17:41 UTC#4
Well I've tried looking for the Brown wire coming off the transmission from another picture that I found on a mazda forum...then I tried the WHITE/RED OR WHITE/BLUE (AC) PCM PIN 1J ...that doesn't work either, I think that's the Throttle sensor or something because the voltage only changes when I hit the gas, then goes back down when I let off. Anyone have any other solutions? I have a 2005 Mazda 3i; 4-Speed Auto Transmission
Posted Aug 19, 2007 · 01:27 UTC#5
go to a wheel speed sensor. not sure on your vehicle but search some mazda forums for wheel speed sensor. once you find it, it will be either one wire or the other since theirs only two wires for the wheel speed sensor. hope this helps somewhat.
