D3 and 2ohm Speakers
By Mykal1999 · Jul 21, 2007in General💬 12 posts👁️ 1,822 views
Posted Jul 21, 2007 · 16:30 UTC#1
In the installation manual it states that the D3 cannot be hooked up to any 2ohm speakers. I am putting the D3 in and I plan on replacing my stock speakers soon, but not right away. Anyway, my stock speakers are 2ohm. Is there a possibilty that I can damage the D3 if I hook it up to the 2 ohm speakers??
Posted Jul 21, 2007 · 20:17 UTC#2
Yes, you can damage you D3 by hooking it to 2 ohm spks. Maybe not right away, but over time yes. It might last 1 to 2 days or even months. It wouldn't be worth the risk for me, but it's your call.
Posted Jul 21, 2007 · 20:27 UTC#3
Do you have factory component speakers (a woofer and tweeter) where each one is 2ohm? In that case, there is probably a crossover box where there is a 4ohm input from the amp. However, if you have coaxial speakers, where the tweeter and woofer are built in to each other, then you may need to replace them. Most, if not all, after market decks are designed to carry 4-8ohm loads.
Posted Jul 21, 2007 · 20:37 UTC#4
My d2 has been running 2 ohm front channel and 4 ohm rear channel because of how my stock system is. I also had an alpine before this and never had a single issue. Alpine has been running for 5 years and just moved to my other car which is the same way and the d2 has been in for a year.
Posted Jul 21, 2007 · 22:50 UTC#5
You've been lucky. To the OP, it's a bad idea for the reason shotgun_customs said.
Posted Jul 21, 2007 · 23:04 UTC#6
OK thanks for the info. The front speakers consist of a 6.5" driver and a separate tweeter. I guess its not worth the risk.
Posted Jul 21, 2007 · 23:05 UTC#7
What kind of vehicle is it anyway?
Posted Jul 22, 2007 · 01:44 UTC#8
Its a 2007 Wrangler Unlimited. I am trying to figure out how the front speakers are wired since there is a 1" tweeter and 6.5" driver in the front.
Posted Jul 22, 2007 · 01:58 UTC#9
How can you tell how many ohms the stock speakers are?
I drive a 2005 Kia Sorento LX (no separate amp like in the EX model). Is there an installer here that can check it out for me? I've had my D3 installed for about a month now with no problems.
There are 4" or 5" speakers in the bottom of the door panels and small tweeters in the middle of the door (near the side mirror controls).
Thanks.
Posted Jul 22, 2007 · 02:29 UTC#10
I did some research on a a jeep forum. That is where I found out that the Jeep speakers are 4ohm. I am still confused about how the front speakers are wired though.
Posted Jul 22, 2007 · 02:37 UTC#11
The midrange and tweet are wired to a crossover network in series. So the tweeter and woofer may each be 2ohm, but they are wired in series so it presents a 4ohm load to the head unit, which is what you want. You should be fine.
When wiring speakers, putting two in parallel halves the ohms. When run in serial config (ala. a crossover), you double the ohms.
http://www.the12volt.com/ohm/ohmslaw.asp
Posted Jul 22, 2007 · 03:06 UTC#12
^^Thanks^^ Makes sense. Ive learned a little bit about the ohm thing from wiring subs. (2) 4ohm speaks wired in series achieves a 8ohm load on the amp.
I just wasnt sure if my head unit had seperate dedicated channels to the front tweeter and driver. It makes sense that they would be wired through a crossover, just wasnt sure if the crossover was in the head unit or outside.
Thanks for the help though!
MOD EDIT
Fixed your numbers. 2 4 ohm speakers in series presents an 8 ohm load. 2 4 ohm speakers in parallel presents a 2 ohm load.
