here it is fellas....damn the people that dont want to help but rather be a pain in da azz....
did this a few times before it worked...try it till it works...it will
The Buttons:
OK = JOYPAD INWARD
BACK = JOYPAD TO THE LEFT (previous menu)
BACK = BAND BUTTON (info button)
Step #1: Accessing the Service Menu (first remove any discs)
Hold Reset & Eject
Release Reset but HOLD nav disc Eject button
The screen with go back in and out, then will say "Please press the reset button"...DONT!
Then with the joystick, press the following:
UP,RIGHT,UP,RIGHT,DOWN,RIGHT,DOWN,RIGHT…THEN OK(press right joystick inwards)
Password screen will come on breifly.
STEP #2: Flashing the Navigation Software
Test mode screen appears - CLICK JOYSTICK TO RIGHT ONCE
Scroll down to #6 - PROGRAM FORCED WRITE (press OK)
INSERT THE NAVIGATION DVD (whichever version you want)
Select #1 SYSTEM PROGRAM (press OK)
Select #2 DVD/CD ROM (press OK)
Select LANGUAGE… (ENGLISH)
PRESS map BUTTON
SHOULD SEE SYSTEM PROGRAM GOING UP IN %
STEP #3: Flashing the Navigation Software Part II
When finished programming in above step, Press (BACK)
Select #6 - PROGRAM FORCED WRITE AGAIN (OK)
Select #3 - APPLICATION PROGRAM (OK)
Select #2 - DVD/CD ROM (OK)
Select English - THEN PRESS map BUTTON (**Select English/UK if you are installing the X1 software)
SHOULD SEE SYSTEM GOING UP IN %
WHEN FINISHED PRESS (BACK)
Go to TEST MODE PAGE 1
SELECT #6 - CLEAR BACK UP MEMORY (OK)
Should say FINISHED and then asks for reset button to be pressed. When prompted, press RESET.
